Reset FRM with Xprog
Mensagempor admin » 17/out/2020, 13:53
In this video i present how reset FRM 3 with Xprog.The FRM dump was corrupted after a discharged battery was used on the car.For make this video i used Xprog V5.55 with rework https://www.diagnoza-auto.net/products/x-prog-v5-55/
If you visit this site,at the end of the description Xprog V5.55,you can find link for download soft for extract eprom from D-flash.This soft work only in WIN 7.
XPROG-M V5.55 ECU Programmer:
1. Versiune software: V5.55;
2. Aceasta versiune de XPROG poate decripta BMW CAS4;
3. A fost adaugata o noua autorizare in aceasta versiune: AUTH-0025 Authorized 11/4/2014;
4. Programatorul este de calitate clasa A+++;
5. Software ruleaza pe Windows 7 (faceti excludere daca aveti instalat antivirus);
6. Dezinstalati versiunile anterioare de XPROG;
Autorizari XPROG-M V5.55:
AUTH-0001 Motorola HC05 family authorization (allows to read/write EEPROM)
AUTH-0002 Motorola HC08 family authorization (allows to read/write EEPROM)
AUTH-0003 Motorola HC11 family authorization (allows to read/write EEPROM)
AUTH-0004 Motorola HC12, 9S12 family authorization (allows to read/write EEPROM and flash memory)
AUTH-0005 Texas Instruments TMS370/TMS374 family authorization (allows to read/write EEPROM)
AUTH-0006 Motorola HC05Bxx and HC05Xxx family bypass security authorization (allows to read/write secured EEPROM and flash memory)
AUTH-0007 ST M35080 authorization. Read/Write/Erase device to delivery state.
AUTH-0008 BMW EWS3 authorization
AUTH-0009 ATMEGA family authorization (allows to read/write EEPROM and flash memory)
AUTH-0010 MB ZGS001 authorization
AUTH-0011 Motorola HC11EA9/E9 bypass security authorization (allows to bypass security bit and read EEPROM and RAM memory)
AUTH-0012 National CR16 authorization (allows to read/write EEPROM memory)
AUTH-0014 ST7, ST10 family authorization (allows to read/write internal flash)
AUTH-0015 MPC5xx authorization (depending on device program automatically detects MPC5xx, M95xxx device type, flash, external flash and configuration memory size)
AUTH-0018 Motorola HC12, HC912, MC9S12, MC9S12X bypass security authorization (allows to read/write secured EEPROM and flash memory)
AUTH-0020 ARM (Micronas, ...) Family authorization (allows to read/write internal flash and external serial EEPROM)
AUTH-0021 ARM (Micronas, ...) Family bypass security authorization (allows to read/write secured and non-secured internal flash and external serial EEPROM, view/change mileage,chassis number (VIN), serial number and PIN code).
AUTH-0023-1 MAC7xxx
AUTH-0023-2 XC23xx
AUTH-0024-1 MC9S12Cxx
AUTH-0024-2 MC9S12XE
AUTH-0024-3 9S12XE SECURITY
AUTH-0024-4 MC9S12HA/HY/P
AUTH-0025-1 MPC/SPC5xxx Authorized 11/4/2014
Adaptoare XPROG-M V5.55:
ADP-0001 TMS370 PLCC28 programming adapter
ADP-0002 TMS370 PLCC44 programming adapter
ADP-0003 TMS370 PLCC68 programming adapter
ADP-0004 Motorola HC05B/X PLCC52 programming adapter
ADP-0005 Motorola HC05B/X QFP64 programming adapter
ADP-0006 ST M35080 in-circuit programming adapter
ADP-0008 TMS374 family in-circuit programming adapter
ADP-0009 MC68HC05V12 programming adapter
ADP-0010 TMS374 on-board programming adapter
ADP-0011 HC11EA9/E9 programming adapter
ADP-0017 HC(S)12 BDM / ARM Micronas in-circuit programming/bypass security adapter
Inventarul pachetului:
1buc x XPROG-Box Hardware (carcasa metal);
19buc x Set de adaptoare pentru programare;
1buc x Cablu USB;
1buc x CD cu XPROG-Box Software (V5.55)
Citește mai mult: https://www.diagnoza-auto.net/products/x-prog-v5-55/
